[petsc-dev] PetscSF in Fortran
Adrian Croucher
a.croucher at auckland.ac.nz
Tue Sep 26 22:49:51 CDT 2017
hi Matt,
On 25/09/17 23:12, Matthew Knepley wrote:
> If you truly need the exact same SF for your grid, you should be able
> to use DMGet/SetPointSF() since it will just reference count it for
> you. Then
> the default SF is created automatically from the point SF. Does this work?
It doesn't seem to work, unfortunately. If I run in parallel I get an
error on each processor like this:
[0]PETSC ERROR: Nonconforming object sizes
[0]PETSC ERROR: SF roots 447 < pEnd 543
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.6-5886-gc423942
GIT Date: 2017-06-28 18:43:52 -0500
[0]PETSC ERROR: test_all on a linux-gnu-c-opt named en-354401 by acro018
Wed Sep 27 16:31:28 2017
[0]PETSC ERROR: Configure options --with-x --download-hdf5
--download-netcdf --download-exodusii --downloa
d-triangle --download-ptscotch --download-chaco --download-hypre
[0]PETSC ERROR: #1 PetscSectionCreateGlobalSection() line 929 in
/home/acro018/software/PETSc/code/src/vec
/is/utils/vsectionis.c
[0]PETSC ERROR: #2 DMGetDefaultGlobalSection() line 3458 in
/home/acro018/software/PETSc/code/src/dm/inter
face/dm.c
[0]PETSC ERROR: #3 User provided function() line 0 in User file
The reason I thought just copying the SF across might work is that the
partition ghost cells in my modified DMPlex should be in the same
locations (DMPlex points) as they were in the original DMPlex. My
understanding was that the SF just stores the root corresponding to a
leaf (ghost point?) on the current processor, so those ought to be
unchanged. But maybe there are subtleties about the SF stuff that I
don't yet understand.
What I am doing is adding new points for the dual-porosity mesh into my
modified DMPlex. I have added the new cells after the partition ghost
cells, and before the boundary ghost cells (and similarly for other
depth strata). So I have shifted the locations of the boundary ghost
cells, but not the partition ghost cells. I give the new points the
appropriate depth label values so that the depth stratum bounds are
updated correctly. I also shift the end_interior value for each depth
stratum, so that code relying on DMPlexGetHybridBounds() should still work.
Would you expect copying the SF to work in this case?
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170927/656c8e37/attachment.html>
