[petsc-dev] DMLabel in Fortran
Matthew Knepley
knepley at gmail.com
Wed Oct 25 05:08:35 CDT 2017
On Tue, Oct 24, 2017 at 4:22 PM, Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> hi,
> On 11/10/17 22:18, Matthew Knepley wrote:
> On Tue, Oct 10, 2017 at 9:07 PM, Adrian Croucher <
> a.croucher at auckland.ac.nz> wrote:
>> hi
>> On 03/08/17 13:10, Matthew Knepley wrote:
>> On Wed, Aug 2, 2017 at 8:06 PM, Adrian Croucher <
>>> I haven't tried this myself, but two of my colleagues are reporting
>>> problems accessing DMLabel from Fortran, when using the latest 'next'
>>> branch.
>>> Previously, #include <petsc/finclude/petsc.h> and then 'use petsc' would
>>> give access to DMLabel.
>>> But now it appears that doesn't work- you need to include petscdmlabel.h
>>> as well.
>>> Is that a bug or a feature?
>> Its a bug. We refactored DMLabel to make all functionality available from
>> Fortran, including using it as a type, but
>> I did not put the new header inside petsc.h. I can do that.
>> Matt
>> It appears this never got done, so I have had a look and (I think)
>> figured out how to fix it myself.
>> I've just submitted a pull request with the fix in a branch called
>> acroucher/fix-fortran-dmlabel.
> Sorry about that. We will get this in this week.
> Was there a problem with that? It doesn't appear to have been merged in
> yet.
This is me being stupid. I needed to rebase it onto maint and I forgot
about it. I merged it to next just now.
If everything is fine tomorrow, I will merge to maint and master.
Matt
> - Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611 <+64%209-923%204611>
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171025/8d52d7da/attachment-0001.html>
