[petsc-dev] DMLabel in Fortran
    Adrian Croucher
    a.croucher at auckland.ac.nz
    Tue Oct 24 15:22:37 CDT 2017
hi,
On 11/10/17 22:18, Matthew Knepley wrote:
> On Tue, Oct 10, 2017 at 9:07 PM, Adrian Croucher
> <a.croucher at auckland.ac.nz <mailto:a.croucher at auckland.ac.nz>> wrote:
>     hi
>     On 03/08/17 13:10, Matthew Knepley wrote:
>>     On Wed, Aug 2, 2017 at 8:06 PM, Adrian Croucher
>>         I haven't tried this myself, but two of my colleagues are
>>         reporting problems accessing DMLabel from Fortran, when using
>>         the latest 'next' branch.
>>         Previously, #include <petsc/finclude/petsc.h> and then 'use
>>         petsc' would give access to DMLabel.
>>         But now it appears that doesn't work- you need to include
>>         petscdmlabel.h as well.
>>         Is that a bug or a feature?
>>     Its a bug. We refactored DMLabel to make all functionality
>>     available from Fortran, including using it as a type, but
>>     I did not put the new header inside petsc.h. I can do that.
>>        Matt
>     It appears this never got done, so I have had a look and (I think)
>     figured out how to fix it myself.
>     I've just submitted a pull request with the fix in a branch called
>     acroucher/fix-fortran-dmlabel.
> Sorry about that. We will get this in this week.
Was there a problem with that? It doesn't appear to have been merged in yet.
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171025/c3cbadac/attachment.html>
