[petsc-dev] MatAssembly and VecAssembly
Jed Brown jed at jedbrown.org
Fri Oct 20 17:47:01 CDT 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
>> On Oct 20, 2017, at 5:33 PM, Kong, Fande <fande.kong at inl.gov> wrote:
>> On Fri, Oct 20, 2017 at 4:24 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> > On Oct 20, 2017, at 12:17 PM, Kong, Fande <fande.kong at inl.gov> wrote:
>> > How about to do  a global check (MPI_Allreduce)?
>>    Kill you for large number of processes.
>> > If we do not set values at all and the matrix is already assembled, we just return without doing anything?
>> > How expensive, in the current implementation,  to call MatAssemblyBegin/End if there are no any stashed data? Is it so cheap that we can just ignore it?
>>    It requires at least one global reduction.
>> So, this global reduction is cheaper than MPI_Allreduce?  Or they are similar.
>   No it is not cheaper, it is the same thing.
The point-to-point communication when using -vec_assembly_bts with
VEC_SUBSET_OFF_PROC_ENTRIES may be slightly less expensive.
>   You need to eliminate unneeded AssemblyBegin/End in MOOSE. That is the only corrective action that can take place.
You should definitely do this rather than trying to hide behind possibly
slightly faster null assembly.
