[petsc-dev] TS Terminology
Fri Oct 20 17:37:54 CDT 2017
> On Oct 20, 2017, at 5:36 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
>> I think you are right that the SNES thing needs fixed as well. The
>> problem has not come up because no one ever uses that interface. It is
>> only there because it makes FAS a lot easier.
> That interface precedes FAS.  It's there because it's convenient.
  It doesn't matter when it started.
