[petsc-dev] TS Terminology
Matthew Knepley
knepley at gmail.com
Fri Oct 20 17:47:57 CDT 2017
On Fri, Oct 20, 2017 at 6:44 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> > I think you are right that the SNES thing needs fixed as well. The
> >> > problem has not come up because no one ever uses that interface. It is
> >> > only there because it makes FAS a lot easier.
> >> That interface precedes FAS. It's there because it's convenient.
> > That is not my memory.
> You made the change. That was long before FAS moved from DMMG into
> SNES.
I know. I was writing FAS, code that no longer exists, and needed that to
make things nice.
Matt
> commit f69a0ea3504314d029ee423e0de2950ece2dab86
> Author: Matthew Knepley <knepley at mcs.anl.gov>
> Date: Tue Mar 15 18:34:40 2005 -0600
> bk-changeset-1.2975.1.5
> knepley at khan.(none)|ChangeSet|20050316003440|07799
> ChangeSet
> 1.2975.1.5 05/03/15 18:34:40 knepley at khan.(none) +235 -0
> Fixed many const arguments
> Changed MatCreate() to only take a communicator
> - Added MatSetSizes()
> Changed SNESSolve() to accept a constant argument
> - This should allow SNES to look almost like KSP
> Added Options methods, SetUp(), and View() and objects which lacked
> them
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171020/65d65020/attachment.html>
