[petsc-dev] TS Terminology
Fri Oct 20 17:30:37 CDT 2017
> On Oct 20, 2017, at 12:20 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>>  The name absolutely has to be changed. But to what? And the manual page is WRONG! You cannot justify that no matter how much you want to keep the current confusing/inaccurate name.
>>> Are you also adamant that SNESComputeFunction must be changed?  After
>>> all, it isn't returning the output of the function that was passed to
>>> SNESSetFunction.  If SNESComputeFunction is okay, but TSComputeIFunction
>>> is not, what is the rationale for that?
>>  In TS it is DAMN!!!! confusing. (Since you and Emil have lived with it from day one I know it is not confusing to you; but it is confusing to everyone else).
> Why is it DAMN!!!! confusing in TS, but exactly the same pattern is
> "very minor" in SNES?  We need an explanation here unless we're going to
> rename all XComputeY() functions to compute exactly Y.
   Please tell us all the XComputeY() that need to be fixed so we can fix them all. I am ready to fix them today.
  Barry
> Is it possible it has something to do with you having spent 30 years
> thinking deeply about Newton solvers and this moving the RHS vector over
> just seems like a trivial and obvious transformation?
>>  In SNES it is a very minor confusion.
>>  We absolutely need to fix things that are DAMN!!!! confusing. Fixing things that are minor confusing is much less important. So it would be fine to change SNESComputeFunction() but I have no reason to be adamant about it.
>>  Barry
