[petsc-dev] TS Terminology
Jed Brown jed at jedbrown.org
Fri Oct 20 11:37:18 CDT 2017
Emil Constantinescu <emconsta at mcs.anl.gov> writes:
> Matt, that depends, if TS method is imex,
Nothing to do with "TS method".  The "imex" parameter is an argument to
the function TSComputeIFunction.  SNESComputeFunction's behavior depends
on whether snes->vec_rhs exists, but TSComputeIFunction's behavior
depends only on the arguments that are passed.
> then it computes just F, not F-G so your argument is not correct. If
> the method can do only implicit it computes F and subtracts G *if
> defined*. If the TS method can only do explicit and you define F then
> it fails.
> Again, this has to do with the TS methods and PETSc doing the work for
> you of packing the functions in different ways.
