[petsc-dev] VecView HDF5 read / write partial array
Matthew Knepley
knepley at gmail.com
Fri Oct 20 17:30:40 CDT 2017
On Fri, Oct 20, 2017 at 4:32 PM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
> Hi,
> Recent versions of exodus are implemented with netcdf4, which is based on
> hdf5.
> Instead of going through the process of rewriting exodus viewers, I would
> like to use PETSc’s HDF5 I/O operations.
> Problem is that as far as I can understand, exodus / netcdf does not use
> hdf5 time steps. Instead, it writes a single vector containing all values
> of a field at all time steps.
> (i.e. if vij denotes the i^th component of v at time step j, v is written
> as a single array v11, v21, v31, . . ., v12, v22, v32, . . ., v13, v23, .
> . .) and so on).
> Is there a way to use VecView hdf5 to read/write only entries kn:(k+1)n-1
> in an hdf5 file?
This is exactly what HDF5 does. You write a 'hyperslab' of the array
corresponding to that time step.
Matt
> Blaise
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~
> bourdin
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171020/efc2c644/attachment-0001.html>
