[petsc-dev] TS Terminology
Barry Smith
bsmith at mcs.anl.gov
Fri Oct 20 11:39:05 CDT 2017
You guys are arguing about irrelevancies. Focus on the NAME, that is what Matt is complaining about.
> On Oct 20, 2017, at 11:37 AM, Jed Brown <jed at jedbrown.org> wrote:
> Emil Constantinescu <emconsta at mcs.anl.gov> writes:
>> Matt, that depends, if TS method is imex,
> Nothing to do with "TS method". The "imex" parameter is an argument to
> the function TSComputeIFunction. SNESComputeFunction's behavior depends
> on whether snes->vec_rhs exists, but TSComputeIFunction's behavior
> depends only on the arguments that are passed.
>> then it computes just F, not F-G so your argument is not correct. If
>> the method can do only implicit it computes F and subtracts G *if
>> defined*. If the TS method can only do explicit and you define F then
>> it fails.
>> Again, this has to do with the TS methods and PETSc doing the work for
>> you of packing the functions in different ways.
