[petsc-dev] TS Terminology
Fri Oct 20 09:11:25 CDT 2017
On Fri, Oct 20, 2017 at 9:23 AM, Emil Constantinescu <emconsta at mcs.anl.gov>
wrote:
> On 10/20/17 7:57 AM, Matthew Knepley wrote:
>> I am confused by some of the terminology in TS. At the top level,
>> IFunction appears to mean the entire equation
>>    F(u, u_t, x) = 0
> Matt, page 141 of the manual: F(t, u, u_t) = G(t, u), and not zero on the
> RHS side. To make the interface general we allow internally for F:= F(t, u,
> u_t) - G(t, u) and then F=0.
This is not "internal". Its the toplevel interface:
https://bitbucket.org/petsc/petsc/src/63ae3ecac3af8ce782273a76ad4152cddc2fd80a/src/ts/interface/ts.c?at=master&fileviewer=file-view-default#ts.c-884
It computes F - G.
   Matt
> Emil
> PS: Manual: PETSc 3.8 September 26, 2017
> However, this appears to mean something different than ifunction at the
>> function pointer level. Inside TSCompiteIFunction(), it uses both ifunction
>> and rhsfunction. This makes it hard to understand how composition works.
>> TSComputeRHS() is called inside TSComputeIFunction(), so if we want to
>> reuse vectors it should not initialize the vector, but it seems like
>> TSComputeIFunction() should initialize the vector since
>> TSComputeIFunctionLocal() does.
>> What guarantees about initialization should we have?
>>     Matt
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171020/f26f42f5/attachment-0001.html>
