[petsc-dev] TS Terminology
    Emil Constantinescu
    emconsta at mcs.anl.gov
    Fri Oct 20 08:23:50 CDT 2017
On 10/20/17 7:57 AM, Matthew Knepley wrote:
> I am confused by some of the terminology in TS. At the top level,
> IFunction appears to mean the entire equation
>    F(u, u_t, x) = 0
Matt, page 141 of the manual: F(t, u, u_t) = G(t, u), and not zero on
the RHS side. To make the interface general we allow internally for F:=
F(t, u, u_t) - G(t, u) and then F=0.
Emil
PS: Manual: PETSc 3.8 September 26, 2017
> However, this appears to mean something different than ifunction at the
> function pointer level. Inside TSCompiteIFunction(), it uses both
> ifunction and rhsfunction. This makes it hard to understand how
> composition works. TSComputeRHS() is called inside TSComputeIFunction(),
> so if we want to reuse vectors it should not initialize the vector, but
> it seems like TSComputeIFunction() should initialize the vector since
> TSComputeIFunctionLocal() does.
> What guarantees about initialization should we have?
>     Matt
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
