[petsc-dev] TS Terminology
Emil Constantinescu
emconsta at mcs.anl.gov
Fri Oct 20 10:22:37 CDT 2017
On 10/20/17 9:11 AM, Matthew Knepley wrote:
> On Fri, Oct 20, 2017 at 9:23 AM, Emil Constantinescu
> <emconsta at mcs.anl.gov <mailto:emconsta at mcs.anl.gov>> wrote:
> On 10/20/17 7:57 AM, Matthew Knepley wrote:
> I am confused by some of the terminology in TS. At the top
> level, IFunction appears to mean the entire equation
> F(u, u_t, x) = 0
> Matt, page 141 of the manual: F(t, u, u_t) = G(t, u), and not zero
> on the RHS side. To make the interface general we allow internally
> for F:= F(t, u, u_t) - G(t, u) and then F=0.
> This is not "internal". Its the toplevel interface:
> https://bitbucket.org/petsc/petsc/src/63ae3ecac3af8ce782273a76ad4152cddc2fd80a/src/ts/interface/ts.c?at=master&fileviewer=file-view-default#ts.c-884
> It computes F - G.
That's what it should do in some cases. The user provides either
ifunction or rhs funtion or both. The api to the solvers can take care
of this stuff automatically - that's what I meant by internal. Different
TS solvers can take different definitions of the funtions; e.g., imex
need both, beuler can take ifuntion and/or rhs function but instead of
writing beuler for both we choose the most general case (ifunction) and
compose the functions accordingly. The F - G is transparent to the user.
But somewhere the sausage needs to be made and I think that is the right
level because that is least likely to change and least maintenance.
Emil
> Matt
> Emil
> PS: Manual: PETSc 3.8 September 26, 2017
> However, this appears to mean something different than ifunction
> at the function pointer level. Inside TSCompiteIFunction(), it
> uses both ifunction and rhsfunction. This makes it hard to
> understand how composition works. TSComputeRHS() is called
> inside TSComputeIFunction(), so if we want to reuse vectors it
> should not initialize the vector, but it seems like
> TSComputeIFunction() should initialize the vector since
> TSComputeIFunctionLocal() does.
> What guarantees about initialization should we have?
> Matt
> experiments is infinitely more interesting than any results to
> which their experiments lead.
> -- Norbert Wiener
> <https://www.cse.buffalo.edu/~knepley/>
> <http://www.caam.rice.edu/~mk51/ <http://www.caam.rice.edu/~mk51/>>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
