[petsc-dev] any way to detect if a matrix is singular?
Hong
hzhang at mcs.anl.gov
Tue Oct 10 09:57:24 CDT 2017
Fande,
'-pc_factor_shift_amount 1' is huge.
Try use petsc default shift amount '1.e-14' by
'-pc_factor_shift_type nonzero' only.
Hong
On Tue, Oct 10, 2017 at 9:40 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Oct 10, 2017 at 10:36 AM, Kong, Fande <fande.kong at inl.gov> wrote:
>> Hi Developers,
>> I am trying to use the native LU in PETSc to compute a matrix (arising
>> from a fluid-structure interaction problem). I encounter a zero pivot. The
>> matrix gives the wrong Newton direction when using "-pc_factor_shift_type
>> nonzero -pc_factor_shift_amount 1". I hence guess the matrix is
>> singular.
>> Any easy way to detect if or not the matrix is singular??
> That is the easiest way, namely having LU fail. You can catch the failure
> and do something useful.
> Matt
>> Fande,
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171010/a28b4e8e/attachment.html>
