[petsc-dev] any way to detect if a matrix is singular?
Kong, Fande
fande.kong at inl.gov
Tue Oct 10 12:20:44 CDT 2017
Thanks, Hong and Matt,
I think the matrix is singular. I will be checking the implementation.
Fande,
On Tue, Oct 10, 2017 at 8:57 AM, Hong <hzhang at mcs.anl.gov> wrote:
> Fande,
> '-pc_factor_shift_amount 1' is huge.
> Try use petsc default shift amount '1.e-14' by
> '-pc_factor_shift_type nonzero' only.
> Hong
> On Tue, Oct 10, 2017 at 9:40 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Oct 10, 2017 at 10:36 AM, Kong, Fande <fande.kong at inl.gov> wrote:
>>> Hi Developers,
>>> I am trying to use the native LU in PETSc to compute a matrix (arising
>>> from a fluid-structure interaction problem). I encounter a zero pivot. The
>>> matrix gives the wrong Newton direction when using "-pc_factor_shift_type
>>> nonzero -pc_factor_shift_amount 1". I hence guess the matrix is
>>> singular.
>>> Any easy way to detect if or not the matrix is singular??
>> That is the easiest way, namely having LU fail. You can catch the failure
>> and do something useful.
>> Matt
>>> Fande,
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.caam.rice.edu_-7Emk51_&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=OzufXo0CFDWCGheboXxUMvKt3soawuoLxqtBqJtH4tc&s=50QybFKpScUhuVT0fSUA4vPnZJrmTUdY0BKJlNOBCS4&e=>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171010/446e152c/attachment.html>
