[petsc-dev] any way to detect if a matrix is singular?
Tue Oct 10 09:40:09 CDT 2017
On Tue, Oct 10, 2017 at 10:36 AM, Kong, Fande <fande.kong at inl.gov> wrote:
> Hi Developers,
> I am trying to use the native LU in PETSc to compute a matrix (arising
> from a fluid-structure interaction problem). I encounter a zero pivot. The
> matrix gives the wrong Newton direction when using "-pc_factor_shift_type
>  nonzero -pc_factor_shift_amount 1".  I hence guess the matrix is
> singular.
> Any easy way to detect if or not the matrix is singular??
That is the easiest way, namely having LU fail. You can catch the failure
and do something useful.
  Matt
> Fande,
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171010/28ad657d/attachment.html>
