[petsc-dev] (no subject)
    Satish Balay
    balay at mcs.anl.gov
    Mon Oct  9 13:58:00 CDT 2017
Yeah - there was request to use both from the same app - hence this was enabled.
https://bitbucket.org/petsc/petsc/commits/c7c7460f87d6ad25fd26bf066c6b521b0702e227
Satish
On Mon, 9 Oct 2017, Lisandro Dalcin wrote:
> Please ignore the previous email. The INSTALL instructions in the
> tarball explicitly state that both libraries should be linked.
> On 9 October 2017 at 15:29, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> > Satish, in PTScotch.py, you check for the parallel (libpt*.a) as well
> > as sequential libraries. Is this correct? Don't you need just the
> > parallel ones?
> > https://bitbucket.org/petsc/petsc/src/maint/config/BuildSystem/config/packages/PTScotch.py?at=master&fileviewer=file-view-default#PTScotch.py-10
> > We are having a discussion in conda-forge about how to package scotch
> > and ptscotch
> > https://github.com/conda-forge/scotch-feedstock/pull/16
> > https://github.com/conda-forge/scotch-feedstock/pull/17
> > Lisandro Dalcin
> > Research Scientist
> > Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> > Extreme Computing Research Center (ECRC)
> > King Abdullah University of Science and Technology (KAUST)
> > http://ecrc.kaust.edu.sa/
> > 4700 King Abdullah University of Science and Technology
> > al-Khawarizmi Bldg (Bldg 1), Office # 0109
> > Thuwal 23955-6900, Kingdom of Saudi Arabia
> > http://www.kaust.edu.sa
> > Office Phone: +966 12 808-0459
