[petsc-dev] (no subject)
    Lisandro Dalcin
    dalcinl at gmail.com
    Mon Oct  9 13:35:25 CDT 2017
Please ignore the previous email. The INSTALL instructions in the
tarball explicitly state that both libraries should be linked.
On 9 October 2017 at 15:29, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> Satish, in PTScotch.py, you check for the parallel (libpt*.a) as well
> as sequential libraries. Is this correct? Don't you need just the
> parallel ones?
> https://bitbucket.org/petsc/petsc/src/maint/config/BuildSystem/config/packages/PTScotch.py?at=master&fileviewer=file-view-default#PTScotch.py-10
> We are having a discussion in conda-forge about how to package scotch
> and ptscotch
> https://github.com/conda-forge/scotch-feedstock/pull/16
> https://github.com/conda-forge/scotch-feedstock/pull/17
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 0109
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
Lisandro Dalcin
Research Scientist
