[petsc-dev] (no subject)
Lisandro Dalcin dalcinl at gmail.com
Mon Oct 9 07:29:38 CDT 2017
Satish, in PTScotch.py, you check for the parallel (libpt*.a) as well
as sequential libraries. Is this correct? Don't you need just the
parallel ones?
https://bitbucket.org/petsc/petsc/src/maint/config/BuildSystem/config/packages/PTScotch.py?at=master&fileviewer=file-view-default#PTScotch.py-10
We are having a discussion in conda-forge about how to package scotch
and ptscotch
https://github.com/conda-forge/scotch-feedstock/pull/16
https://github.com/conda-forge/scotch-feedstock/pull/17
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 0109
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
