[petsc-dev] transitioning more PETSc tests to new harness before next release
Sat Oct 7 20:57:33 CDT 2017
On Sat, Oct 7, 2017 at 9:41 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > This seems masochistic. I want to run a test with a different number
> > of processes.  So my best option is print out the options, cut & paste
> > that soewhere, alter it to what I want, and run? Why would we have
> > EXTRA_OPTIONS?
> I often want to run in a debugger with a command like
>   mpiexec -n 2 xterm -e gdb -ex 'b file.c:123' -ex r --args ./ex12
> -some_options
> which just seems painful any other way.  But if you want to write that
> by remembering a collection of variables through which to pass each
> part, I won't stop you.
Good, don't stop me. Also don't prevent use from putting NPROCS into the
test harness.
  Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171007/e4790de2/attachment.html>
