[petsc-dev] transitioning more PETSc tests to new harness before next release
Jed Brown jed at jedbrown.org
Sat Oct 7 20:41:39 CDT 2017
Matthew Knepley <knepley at gmail.com> writes:
> This seems masochistic. I want to run a test with a different number
> of processes.  So my best option is print out the options, cut & paste
> that soewhere, alter it to what I want, and run? Why would we have
> EXTRA_OPTIONS?
I often want to run in a debugger with a command like
  mpiexec -n 2 xterm -e gdb -ex 'b file.c:123' -ex r --args ./ex12 -some_options
which just seems painful any other way.  But if you want to write that
by remembering a collection of variables through which to pass each
part, I won't stop you.
