[petsc-dev] nightlybuilds (next vs next-tmp)
Scott Kruger
kruger at txcorp.com
Thu Nov 16 14:48:44 CST 2017
> ./config/gmakegentest.py --petsc-arch=arch-master-debug
> I have encountered a strange behavior, perhaps only on my machine, where
> if I do not run
> PETSC_ARCH=arch-master-debug
> then it does not update correctly.
I don't know what's going on.
The key lines are:
parser.add_option('--petsc-arch', help='Set PETSC_ARCH different
from environment', default=os.environ.get('PETSC_ARCH'))
main(petsc_arch=opts.petsc_arch, output=opts.output, ...)
So certainly your second case is redundant. The first problem
indicates a problem with config/gmakegen.py since I inherit from
that. I'm at SC right now -- I can take a look later.
Scott
> Thanks,
> Matt
> this parses all the examples and sets up the scripts that are run to
> do the testing. Then use, for example,
> make -f gmakefile test globsearch='*heat*'
> to run all tests that have heat in the example name or path. Or you
> can do
> make -f gmakefile test globsearch='dm*'
> to run all tests in the dm directories. Sometimes you need a little
> trial and error to get the globsearch right to run your example and
> not others.
> You will get a little frustrated the first couple times you do it,
> just bug us and we'll help you get past the stumbling blocks.
> Barry
> > Matt
> > --Richard
> > > Matt
> > > All logs record time. And Karl's script summarizes those times
> on the
> > > dashboard. For eg:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/11/maint.html
> <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/11/maint.html>
> > > If you want to do some analysis on those times - you can grab the
> > > [historical] logs and run the required analysis.
> > > Satish
> > > What most experimenters take for granted before they begin
> their experiments is infinitely more interesting than any results to
> which their experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> <https://www.cse.buffalo.edu/~knepley/>
> > What most experimenters take for granted before they begin their
> experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
Tech-X Corporation kruger at txcorp.com
5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
Boulder, CO 80303 Fax: (303) 448-7756
