[petsc-dev] nightlybuilds (next vs next-tmp)
Jed Brown
jed at jedbrown.org
Thu Nov 16 23:14:54 CST 2017
Scott Kruger <kruger at txcorp.com> writes:
>> ./config/gmakegentest.py --petsc-arch=arch-master-debug
>> I have encountered a strange behavior, perhaps only on my machine, where
>> if I do not run
>> PETSC_ARCH=arch-master-debug
>> then it does not update correctly.
> I don't know what's going on.
> The key lines are:
> parser.add_option('--petsc-arch', help='Set PETSC_ARCH different
> from environment', default=os.environ.get('PETSC_ARCH'))
> main(petsc_arch=opts.petsc_arch, output=opts.output, ...)
Scott, I suspect this is your problem: you should pass petsc_dir and
petsc_arch along instead of passing None which will cause gmakegen:Petsc
get them from the environment.
class generateExamples(Petsc):
gmakegen.py has basic structure for finding the files, writing out
the dependencies, etc.
def __init__(self,petsc_dir=None, petsc_arch=None, verbose=False, single_ex=False):
super(generateExamples, self).__init__(petsc_dir=None, petsc_arch=None, verbose=False)
