[petsc-dev] nightlybuilds (next vs next-tmp)
Matthew Knepley
knepley at gmail.com
Thu Nov 16 06:33:22 CST 2017
On Wed, Nov 15, 2017 at 10:48 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
wrote:
> > On Nov 15, 2017, at 8:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Wed, Nov 15, 2017 at 8:56 PM, Richard Tran Mills <rtmills at anl.gov>
> wrote:
> > On Sun, Nov 12, 2017 at 9:54 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > > On Nov 12, 2017, at 11:21 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > On Sun, Nov 12, 2017 at 12:17 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > On Sun, 12 Nov 2017, Matthew Knepley wrote:
> > > > Have we tried histogramming test times? It would be nice to know how
> much
> > > > cumulative
> > > > time it takes to run 37%, 67%, 95%, etc.
> > > I'm not sure what 'histogramming test time' means.
> > > The below looked like cumulative times over all tests. I want the time
> for each test, and then
> > > we bin them into say 10s wide bins and see which ones are taking the
> most time.
> > WE FREAKING NEED TO CONVERT TO THE NEW TEST HARNESS TO DO THIS, then
> it is easy.
> > So everyone, please, instead of spending twenty minutes a day sending
> and reading email about testing spend 20 minutes a day converting examples
> from the old tests to the new harness!!!!!
> > For those of us who have no idea how to do this, could someone please
> give me a pointer or two on where to look for an example or two or some
> documentation? I should probably be spending a few minutes a day converting
> some examples, but I don't know how or where to start.
> > There is a manual chapter on the test system, but for cut & paste
> semantics, you can look at SNES which has a lot of converted examples.
> > Basically, you take each test entry from the makefile, and move it into
> the source file itself.
> Richard,
> Scott wrote a tool to semi-automatically do it from the makefile but
> sadly the tool is currently broken (it had no nightly testing) and like
> most python code is undebuggable. Anyways after you have put a test in
> the example source code manually as Matt says, you run from PETSC_DIR
> ./config/gmakegentest.py
You give the arch
./config/gmakegentest.py --petsc-arch=arch-master-debug
I have encountered a strange behavior, perhaps only on my machine, where if
I do not run
PETSC_ARCH=arch-master-debug
then it does not update correctly.
Matt
> this parses all the examples and sets up the scripts that are run to do
> the testing. Then use, for example,
> make -f gmakefile test globsearch='*heat*'
> to run all tests that have heat in the example name or path. Or you can do
> make -f gmakefile test globsearch='dm*'
> to run all tests in the dm directories. Sometimes you need a little trial
> and error to get the globsearch right to run your example and not others.
> You will get a little frustrated the first couple times you do it, just
> bug us and we'll help you get past the stumbling blocks.
> Barry
> > Matt
> > --Richard
> > > Matt
> > > All logs record time. And Karl's script summarizes those times on the
> > > dashboard. For eg:
> > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
> 2017/11/11/maint.html
> > > If you want to do some analysis on those times - you can grab the
> > > [historical] logs and run the required analysis.
> > > Satish
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171116/173ca9fb/attachment.html>
