[petsc-dev] PETSc 3.8.2 and Sundials 3.0.0
Matthew Knepley
knepley at gmail.com
Wed Nov 15 13:58:02 CST 2017
Do you have any idea what they changed the name of CVSpgmr to in 3.0?
Matt
On Wed, Nov 15, 2017 at 2:53 PM, Antonio Trande <anto.trande at gmail.com>
wrote:
> Hi all.
> I can't build 'PETSc 3.8.*' with MPI against new 'Sundials-3.0.0':
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
> for details):
> --with-sundials-lib=['-L/usr/lib64/openmpi/lib',
> '-lsundials_nvecparallel'] and
> --with-sundials-include=['/usr/include/openmpi-x86_64'] did not work
> configure.log reports something like that:
> Executing: /usr/lib64/openmpi/bin/mpicc -o
> /tmp/petsc-080_o1/config.libraries/conftest -Wl,-z,relro -Wl,-z,now
> -fPIC -O2 -g -pipe -Wall -Werror=format-security
> -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong
> --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -O3
> -Wl,-z,now -fPIC /tmp/petsc-080_o1/config.libraries/conftest.o
> -L/usr/lib64/openmpi/lib -lsundials_nvecparallel -lopenblas -lm -ldl
> Possible ERROR while running linker: exit code 256
> stderr:
> /tmp/petsc-080_o1/config.libraries/conftest.o: In function
> `_check_CVSpgmr':
> /tmp/petsc-080_o1/config.libraries/conftest.c:5: undefined reference to
> `CVSpgmr'
> collect2: error: ld returned 1 exit status
> 'configure.log' is attached.
> Antonio Trande
> sagitter AT fedoraproject dot org
> See my vCard.
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171115/6d190049/attachment-0001.html>
