[petsc-dev] PETSc 3.8.2 and Sundials 3.0.0
Antonio Trande
anto.trande at gmail.com
Wed Nov 15 13:53:10 CST 2017
Hi all.
I can't build 'PETSc 3.8.*' with MPI against new 'Sundials-3.0.0':
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
for details):
--with-sundials-lib=['-L/usr/lib64/openmpi/lib',
'-lsundials_nvecparallel'] and
--with-sundials-include=['/usr/include/openmpi-x86_64'] did not work
configure.log reports something like that:
Executing: /usr/lib64/openmpi/bin/mpicc -o
/tmp/petsc-080_o1/config.libraries/conftest -Wl,-z,relro -Wl,-z,now
-fPIC -O2 -g -pipe -Wall -Werror=format-security
-Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong
--param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -O3
-Wl,-z,now -fPIC /tmp/petsc-080_o1/config.libraries/conftest.o
-L/usr/lib64/openmpi/lib -lsundials_nvecparallel -lopenblas -lm -ldl
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-080_o1/config.libraries/conftest.o: In function `_check_CVSpgmr':
/tmp/petsc-080_o1/config.libraries/conftest.c:5: undefined reference to
`CVSpgmr'
collect2: error: ld returned 1 exit status
'configure.log' is attached.
Antonio Trande
sagitter AT fedoraproject dot org
See my vCard.
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171115/55020741/attachment.zip>
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171115/55020741/attachment.vcf>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171115/55020741/attachment.sig>
