[petsc-dev] broken nightlybuilds (next vs next-tmp)
Jed Brown
jed at jedbrown.org
Mon Nov 6 12:12:02 CST 2017
Satish Balay <balay at mcs.anl.gov> writes:
> On Sun, 5 Nov 2017, Satish Balay wrote:
>> > $ git fetch -p && comm -12 <(git branch -r --merged origin/next-tmp | sort) <(git branch -r --no-merged origin/master | sort)
>> > origin/hongzh/copy_l2g_stencil
>> > origin/jed/fix-dmcoarsenhookadd-identical
>> > origin/knepley/feature-ex11-shock-test
>> origin/barry/remove-unneeded-use-of-petscdatatype
> Actually origin/hongzh/copy_l2g_stencil had issues [and so did
> origin/barry/remove-petscdatatype-dmgetworkarray] So the branches that
> got tested are:
> origin/barry/delete-adjoint-trajectory
> origin/barry/use-mpi-datatype-F90Array
> origin/stefano_zampini/fix-missing-locks-tao
> origin/tristan/mat-invert-block-diagonal-mat
> Jed,
> Is origin/jed/fix-dmcoarsenhookadd-identical destined for maint or master?
maint.
> Barry,
> There is one regression with: origin/barry/remove-unneeded-use-of-petscdatatype
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/06/examples_full_next-tmp.log
> Build on grind arch-linux-opt-cxx-quad TESTMODE=testexamples DUMMYARGUMENT=foobar Mon Nov 6 06:09:25 CST 2017
>> [ 0]3200 bytes PetscViewerVTKFWrite() line 265 in /sandbox/petsc/petsc.clone-3/src/sys/classes/viewer/impls/vtk/vtkv.c
> Looks like dtype is getting reset before reuse.
> Is the following fix ok?
> Thanks,
> Satish
> $ git diff |cat
> diff --git a/src/sys/classes/viewer/impls/vtk/vtkv.c b/src/sys/classes/viewer/impls/vtk/vtkv.c
> index 7f72665f9e..58caed1a62 100644
> --- a/src/sys/classes/viewer/impls/vtk/vtkv.c
> +++ b/src/sys/classes/viewer/impls/vtk/vtkv.c
> @@ -245,6 +245,7 @@ PetscErrorCode PetscViewerVTKFWrite(PetscViewer viewer,FILE *fp,const void *data
> PetscErrorCode ierr;
> PetscMPIInt rank;
> + MPI_Datatype vdtype=dtype;
> #if defined(PETSC_USE_REAL___FLOAT128)
> double *tmp;
> PetscInt i;
> @@ -265,10 +266,10 @@ PetscErrorCode PetscViewerVTKFWrite(PetscViewer viewer,FILE *fp,const void *data
> ierr = PetscMalloc1(n,&tmp);CHKERRQ(ierr);
> for (i=0; i<n; i++) tmp[i] = ttmp[i];
> data = (void*) tmp;
> - dtype = MPI_DOUBLE;
> + vdtype = MPI_DOUBLE;
> #endif
> - ierr = MPI_Type_size(dtype,&dsize);
> + ierr = MPI_Type_size(vdtype,&dsize);
> bytes = PetscVTKIntCast(dsize*n);
> count = fwrite(&bytes,sizeof(int),1,fp);
