[petsc-dev] broken nightlybuilds (next vs next-tmp)
Satish Balay
balay at mcs.anl.gov
Mon Nov 6 10:00:13 CST 2017
On Sun, 5 Nov 2017, Satish Balay wrote:
> > $ git fetch -p && comm -12 <(git branch -r --merged origin/next-tmp | sort) <(git branch -r --no-merged origin/master | sort)
> > origin/hongzh/copy_l2g_stencil
> > origin/jed/fix-dmcoarsenhookadd-identical
> > origin/knepley/feature-ex11-shock-test
> origin/barry/remove-unneeded-use-of-petscdatatype
Actually origin/hongzh/copy_l2g_stencil had issues [and so did
origin/barry/remove-petscdatatype-dmgetworkarray] So the branches that
got tested are:
origin/barry/delete-adjoint-trajectory
origin/barry/use-mpi-datatype-F90Array
origin/stefano_zampini/fix-missing-locks-tao
origin/tristan/mat-invert-block-diagonal-mat
Jed,
Is origin/jed/fix-dmcoarsenhookadd-identical destined for maint or master?
Barry,
There is one regression with: origin/barry/remove-unneeded-use-of-petscdatatype
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/06/examples_full_next-tmp.log
Build on grind arch-linux-opt-cxx-quad TESTMODE=testexamples DUMMYARGUMENT=foobar Mon Nov 6 06:09:25 CST 2017
> [ 0]3200 bytes PetscViewerVTKFWrite() line 265 in /sandbox/petsc/petsc.clone-3/src/sys/classes/viewer/impls/vtk/vtkv.c
Looks like dtype is getting reset before reuse.
Is the following fix ok?
Satish
$ git diff |cat
diff --git a/src/sys/classes/viewer/impls/vtk/vtkv.c b/src/sys/classes/viewer/impls/vtk/vtkv.c
index 7f72665f9e..58caed1a62 100644
--- a/src/sys/classes/viewer/impls/vtk/vtkv.c
+++ b/src/sys/classes/viewer/impls/vtk/vtkv.c
@@ -245,6 +245,7 @@ PetscErrorCode PetscViewerVTKFWrite(PetscViewer viewer,FILE *fp,const void *data
PetscErrorCode ierr;
PetscMPIInt rank;
+ MPI_Datatype vdtype=dtype;
#if defined(PETSC_USE_REAL___FLOAT128)
double *tmp;
PetscInt i;
@@ -265,10 +266,10 @@ PetscErrorCode PetscViewerVTKFWrite(PetscViewer viewer,FILE *fp,const void *data
ierr = PetscMalloc1(n,&tmp);CHKERRQ(ierr);
for (i=0; i<n; i++) tmp[i] = ttmp[i];
data = (void*) tmp;
- dtype = MPI_DOUBLE;
+ vdtype = MPI_DOUBLE;
#endif
- ierr = MPI_Type_size(dtype,&dsize);
+ ierr = MPI_Type_size(vdtype,&dsize);
bytes = PetscVTKIntCast(dsize*n);
count = fwrite(&bytes,sizeof(int),1,fp);
