[petsc-dev] broken nightlybuilds (next vs next-tmp)
Mon Nov 6 13:09:03 CST 2017
On Mon, 6 Nov 2017, Jed Brown wrote:
> > $ git fetch -p && comm -12 <(git branch -r --merged origin/next-tmp | sort) <(git branch -r --no-merged origin/master | sort)
> >   origin/barry/delete-adjoint-trajectory
> >   origin/barry/remove-unneeded-use-of-petscdatatype
> >   origin/barry/use-mpi-datatype-F90Array
> >   origin/jed/fix-dmcoarsenhookadd-identical
> >   origin/knepley/feature-ex11-shock-test
> >   origin/stefano_zampini/fix-missing-locks-tao
> >   origin/tristan/mat-invert-block-diagonal-mat
> > Jed,
> > Is origin/jed/fix-dmcoarsenhookadd-identical destined for maint or master?
> maint.
Thanks! Merged origin/jed/fix-dmcoarsenhookadd-identical to maint - and the rest to master.
> > Barry,
> > There is one regression with: origin/barry/remove-unneeded-use-of-petscdatatype
> > Looks like dtype is getting reset before reuse.
> > Is the following fix ok?
Pushed the fix and merged origin/barry/remove-unneeded-use-of-petscdatatype to master.
Satish
