[petsc-dev] DMPlexCreateMedFromFile broken
    Matthew Knepley
    knepley at gmail.com
    Fri Nov  3 13:58:27 CDT 2017
On Thu, Nov 2, 2017 at 12:08 PM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
wrote:
> It seems that DMPlexCreateMedFromFile leaves out some mesh elements. I
> found it out when investigating why ParMetis redistribution crashes.
> I attach the datafile $PETSC_DIR/share/petsc/datafiles/meshes/blockcylinder-50.exo
> converted to GMSH and MED format.
> The conversion EXO to GMSH was done by meshio (github.com/nschloe/meshio),
> and GMSH to MED by GMSH itself.
> I did:
> cd $PETSC_DIR/src/dm/impls/plex/examples/tutorials
> make ex5
> FILE=blockcylinder-50.exo && ./ex5 -filename $FILE -dm_view hdf5:$FILE.h5
> && $PETSC_DIR/bin/petsc_gen_xdmf.py $FILE.h5
> FILE=blockcylinder-50.msh && ./ex5 -filename $FILE -dm_view hdf5:$FILE.h5
> FILE=blockcylinder-50.med && ./ex5 -filename $FILE -dm_view hdf5:$FILE.h5
> While the output from blockcylinder-50.exo and blockcylinder-50.msh looks
> OK, that from blockcylinder-50.med is corrupted.
Hi Vaclav,
You are right that something is wrong. Its easy to verify that the number
of cells and vertices is the same in all meshes. Look at the difference
in Plex outputs, it appears that some cells are not correctly oriented:
knepley/feature-adaptor-plex
*$:/PETSc3/petsc/petsc-dev/src/dm/impls/plex/examples/tutorials/vaclav$
../ex5 -filename ./inputs/blockcylinder-50.exo -dm_view ::ascii_info_detail
> err1
../ex5 -filename ./inputs/blockcylinder-50.msh -dm_view ::ascii_info_detail
> err2
diff err1 err2
1c1
< DM Object: cubit(blockcylinder-50.exo): 02/04/2013: 17:50:28 1 MPI
processes
> DM Object: 1 MPI processes
3c3
< Mesh 'cubit(blockcylinder-50.exo): 02/04/2013: 17:50:28':
> Mesh 'DM_0x84000000_0':
 1knepley/feature-adaptor-plex
../ex5 -filename ./inputs/blockcylinder-50.med -dm_view ::ascii_info_detail
> err3
diff err1 err3
1c1
processes
3c3
461,462d460
< [0]: 0 <---- 61 (0)
< [0]: 0 <---- 62 (0)
463a462,463
> [0]: 0 <---- 62 (0)
> [0]: 0 <---- 61 (0)
469,470d468
< [0]: 1 <---- 61 (0)
< [0]: 1 <---- 66 (0)
471a470,471
> [0]: 1 <---- 66 (0)
> [0]: 1 <---- 61 (0)
477,478d476
< [0]: 2 <---- 70 (0)
< [0]: 2 <---- 71 (0)
479a478,479
> [0]: 2 <---- 71 (0)
> [0]: 2 <---- 70 (0)
485,486d484
< [0]: 3 <---- 74 (0)
< [0]: 3 <---- 75 (0)
487a486,487
> [0]: 3 <---- 75 (0)
> [0]: 3 <---- 74 (0)
493,494d492
< [0]: 4 <---- 78 (0)
< [0]: 4 <---- 79 (0)
495a494,495
> [0]: 4 <---- 79 (0)
> [0]: 4 <---- 78 (0)
501,502d500
< [0]: 5 <---- 79 (0)
< [0]: 5 <---- 82 (0)
503a502,503
> [0]: 5 <---- 82 (0)
> [0]: 5 <---- 79 (0)
509,510d508
< [0]: 6 <---- 78 (0)
< [0]: 6 <---- 85 (0)
511a510,511
> [0]: 6 <---- 85 (0)
> [0]: 6 <---- 78 (0)
517,518d516
< [0]: 7 <---- 88 (0)
< [0]: 7 <---- 89 (0)
519a518,519
> [0]: 7 <---- 89 (0)
> [0]: 7 <---- 88 (0)
525,526d524
< [0]: 8 <---- 92 (0)
< [0]: 8 <---- 93 (0)
527a526,527
> [0]: 8 <---- 93 (0)
> [0]: 8 <---- 92 (0)
533,534d532
< [0]: 9 <---- 99 (0)
< [0]: 9 <---- 100 (0)
535a534,535
> [0]: 9 <---- 99 (0)
541,542d540
< [0]: 10 <---- 93 (0)
< [0]: 10 <---- 92 (0)
543a542,543
549,550d548
< [0]: 11 <---- 71 (0)
< [0]: 11 <---- 75 (0)
551a550,551
557,558d556
< [0]: 12 <---- 105 (0)
< [0]: 12 <---- 67 (0)
559a558,559
565,566d564
< [0]: 13 <---- 100 (0)
< [0]: 13 <---- 85 (0)
567a566,567
573,574d572
< [0]: 14 <---- 57 (0)
< [0]: 14 <---- 58 (0)
575a574,575
581,582d580
< [0]: 15 <---- 57 (0)
< [0]: 15 <---- 64 (0)
583a582,583
589,590d588
< [0]: 16 <---- 68 (0)
< [0]: 16 <---- 69 (0)
591a590,591
597,598d596
< [0]: 17 <---- 72 (0)
< [0]: 17 <---- 73 (0)
599a598,599
605,606d604
< [0]: 18 <---- 76 (0)
< [0]: 18 <---- 77 (0)
607a606,607
613,614d612
< [0]: 19 <---- 77 (0)
< [0]: 19 <---- 80 (0)
615a614,615
621,622d620
< [0]: 20 <---- 76 (0)
< [0]: 20 <---- 84 (0)
623a622,623
629,630d628
< [0]: 21 <---- 86 (0)
< [0]: 21 <---- 87 (0)
631a630,631
637,638d636
< [0]: 22 <---- 90 (0)
< [0]: 22 <---- 91 (0)
639a638,639
645,646d644
< [0]: 23 <---- 95 (0)
< [0]: 23 <---- 96 (0)
647a646,647
653,654d652
< [0]: 24 <---- 91 (0)
< [0]: 24 <---- 90 (0)
655a654,655
661,662d660
< [0]: 25 <---- 69 (0)
< [0]: 25 <---- 73 (0)
663a662,663
669,670d668
< [0]: 26 <---- 104 (0)
< [0]: 26 <---- 65 (0)
671a670,671
677,678d676
< [0]: 27 <---- 96 (0)
< [0]: 27 <---- 84 (0)
679a678,679
685,686d684
< [0]: 28 <---- 107 (0)
< [0]: 28 <---- 108 (0)
687a686,687
693,694d692
< [0]: 29 <---- 107 (0)
< [0]: 29 <---- 110 (0)
695a694,695
701,702d700
< [0]: 30 <---- 112 (0)
< [0]: 30 <---- 113 (0)
703a702,703
709,710d708
< [0]: 31 <---- 114 (0)
< [0]: 31 <---- 115 (0)
711a710,711
717,718d716
< [0]: 32 <---- 116 (0)
< [0]: 32 <---- 117 (0)
719a718,719
725,726d724
< [0]: 33 <---- 117 (0)
< [0]: 33 <---- 118 (0)
727a726,727
733,734d732
< [0]: 34 <---- 116 (0)
< [0]: 34 <---- 120 (0)
735a734,735
741,742d740
< [0]: 35 <---- 121 (0)
< [0]: 35 <---- 122 (0)
743a742,743
749,750d748
< [0]: 36 <---- 123 (0)
< [0]: 36 <---- 124 (0)
751a750,751
757,758d756
< [0]: 37 <---- 126 (0)
< [0]: 37 <---- 127 (0)
759a758,759
765,766d764
< [0]: 38 <---- 124 (0)
< [0]: 38 <---- 123 (0)
767a766,767
773,774d772
< [0]: 39 <---- 113 (0)
< [0]: 39 <---- 115 (0)
775a774,775
781,782d780
< [0]: 40 <---- 130 (0)
< [0]: 40 <---- 111 (0)
783a782,783
789,790d788
< [0]: 41 <---- 127 (0)
< [0]: 41 <---- 120 (0)
791a790,791
797,798d796
< [0]: 42 <---- 132 (0)
< [0]: 42 <---- 133 (0)
799a798,799
805,806d804
< [0]: 43 <---- 132 (0)
< [0]: 43 <---- 135 (0)
807a806,807
813,814d812
< [0]: 44 <---- 137 (0)
< [0]: 44 <---- 138 (0)
815a814,815
821,822d820
< [0]: 45 <---- 139 (0)
< [0]: 45 <---- 140 (0)
823a822,823
829,830d828
< [0]: 46 <---- 141 (0)
< [0]: 46 <---- 142 (0)
831a830,831
837,838d836
< [0]: 47 <---- 142 (0)
< [0]: 47 <---- 143 (0)
839a838,839
845,846d844
< [0]: 48 <---- 141 (0)
< [0]: 48 <---- 145 (0)
847a846,847
853,854d852
< [0]: 49 <---- 146 (0)
< [0]: 49 <---- 147 (0)
855a854,855
861,862d860
< [0]: 50 <---- 148 (0)
< [0]: 50 <---- 149 (0)
863a862,863
869,870d868
< [0]: 51 <---- 151 (0)
< [0]: 51 <---- 152 (0)
871a870,871
877,878d876
< [0]: 52 <---- 149 (0)
< [0]: 52 <---- 148 (0)
879a878,879
885,886d884
< [0]: 53 <---- 138 (0)
< [0]: 53 <---- 140 (0)
887a886,887
893,894d892
< [0]: 54 <---- 155 (0)
< [0]: 54 <---- 136 (0)
895a894,895
901,902d900
< [0]: 55 <---- 152 (0)
< [0]: 55 <---- 145 (0)
903a902,903
I think this is a bug in GMsh as it appears to give us MED cells with wrong
orientations. Let me see about checking
and correcting the orientations.
      Matt
> I also attach my HDF5/XDMF outputs and screenshots from ParaView.
> Vaclav
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171103/77fbacbb/attachment.html>
