[petsc-dev] DMPlexCreateMedFromFile broken
Sun Nov 5 11:48:58 CST 2017
On Thu, Nov 2, 2017 at 12:08 PM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
wrote:
> It seems that DMPlexCreateMedFromFile leaves out some mesh elements. I
> found it out when investigating why ParMetis redistribution crashes.
> I attach the datafile $PETSC_DIR/share/petsc/datafiles/meshes/blockcylinder-50.exo
> converted to GMSH and MED format.
> The conversion EXO to GMSH was done by meshio (github.com/nschloe/meshio),
> and GMSH to MED by GMSH itself.
> I did:
> cd $PETSC_DIR/src/dm/impls/plex/examples/tutorials
> make ex5
> FILE=blockcylinder-50.exo && ./ex5 -filename $FILE -dm_view hdf5:$FILE.h5
> && $PETSC_DIR/bin/petsc_gen_xdmf.py $FILE.h5
> FILE=blockcylinder-50.msh && ./ex5 -filename $FILE -dm_view hdf5:$FILE.h5
> FILE=blockcylinder-50.med && ./ex5 -filename $FILE -dm_view hdf5:$FILE.h5
> While the output from blockcylinder-50.exo and blockcylinder-50.msh looks
> OK, that from blockcylinder-50.med is corrupted.
> I also attach my HDF5/XDMF outputs and screenshots from ParaView.
It appears that MED, at least coming from GMsh, inverts hexes just like
GMsh does. I have fixed this in branch
  knepley/fix-plex-med-orientation
If you run your test in this, everything should be fine.
Michael, can you check whether this is a general fix, or it only applied to
MED from GMsh?
     Matt
> Vaclav
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171105/c8d09e3f/attachment-0001.html>
