[petsc-dev] snes/ex56 target is gone
    Scott Kruger
    kruger at txcorp.com
    Wed Jun 28 14:53:44 CDT 2017
On 6/28/17 1:42 PM, Barry Smith wrote:
>> On Jun 28, 2017, at 2:39 PM, Scott Kruger <kruger at txcorp.com> wrote:
>> On 6/28/17 1:35 PM, Jed Brown wrote:
>>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>>     Jed,
>>>>      Aside from its name and location this is a very useful thing. Should it be in $PETSC_DIR/lib/petsc/conf/ ? since it cannot stay in $PETSC_DIR for --prefix installs?
>>> I guess that's a reasonable location.  The file isn't platform-dependent
>>> so it could go elsewhere.  In that location, it should acquire a line
>>> specifying PETSC_ARCH upon install.  The only issue with the path is
>>> that you're actually typing it on the command line, and that would be
>>> a starter Makefile for anyone building a larger project.
>> I would prefer share as it's not critical to the conf
>> and is more user oriented (I think of lib/petsc/conf
>> as internal to petsc stuff).
>    So $PETSC_DIR/share/petsc/?
What would be perfect for me with something like Makefile.example as
the name.
Scott
>     That is fine with me.
>> Also, the shallower the location the better.
>> Scott
>> Tech-X Corporation               kruger at txcorp.com
>> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
>> Boulder, CO 80303                Fax:   (303) 448-7756
