[petsc-dev] snes/ex56 target is gone
Barry Smith
bsmith at mcs.anl.gov
Wed Jun 28 14:42:39 CDT 2017
> On Jun 28, 2017, at 2:39 PM, Scott Kruger <kruger at txcorp.com> wrote:
> On 6/28/17 1:35 PM, Jed Brown wrote:
>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>> Jed,
>>> Aside from its name and location this is a very useful thing. Should it be in $PETSC_DIR/lib/petsc/conf/ ? since it cannot stay in $PETSC_DIR for --prefix installs?
>> I guess that's a reasonable location. The file isn't platform-dependent
>> so it could go elsewhere. In that location, it should acquire a line
>> specifying PETSC_ARCH upon install. The only issue with the path is
>> that you're actually typing it on the command line, and that would be
>> a starter Makefile for anyone building a larger project.
> I would prefer share as it's not critical to the conf
> and is more user oriented (I think of lib/petsc/conf
> as internal to petsc stuff).
So $PETSC_DIR/share/petsc/?
That is fine with me.
> Also, the shallower the location the better.
> Scott
> Tech-X Corporation kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
> Boulder, CO 80303 Fax: (303) 448-7756
