[petsc-dev] make -f gmakefile test needs a proper help message of some sort
    Scott Kruger
    kruger at txcorp.com
    Tue Jun 20 17:23:17 CDT 2017
On 6/17/17 9:57 PM, Jed Brown wrote:
> Matthew Knepley <knepley at gmail.com> writes:
>> On Sat, Jun 17, 2017 at 6:19 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>>    Thanks, sadly it is not helpful.
>>> I wasn't saying it worked now, but that it was the target that should be
>>> used to print help.
>> <insert broken fingers message>
> Barry's original message was addressed to Scott.  I was merely pointing
> out a convention that is more discoverable than Barry's suggestion.  I
> claim this was a constructive comment, not bikeshedding.  Yes, I could
> make this change, but so could you, Barry, or anyone else.  I don't
> think it's productive to lob the "broken fingers" criticism around.
> It's educational and likely more accurate for the person who wrote a
> component to maintain the docs for that component and the person making
> the suggestion might have the 30 seconds at that moment to make a
> constructive suggestion, but not the 10 minutes to implement it.
>> where are the current docs for it that we move to this place?
> gmakefile has this comment.
> # Tests can be generated by searching
> # Percent is a wildcard (only one allowed):
> #    make -f gmakefile test search=sys%ex2
> # To match internal substrings (matches *ex2*):
> #    make -f gmakefile test searchin=ex2
> # Search and searchin can be combined:
> #    make -f gmakefile test search='sys%' searchin=ex2
> # For args:
> #    make -f gmakefile test argsearch=cuda
> # For general glob-style searching using python:
> # NOTE: uses shell which is possibly slower and is possibly more brittle
> #    make -f gmakefile test pysearch='sys*ex2*'
I'll also note that per request, there is documentation
in the developers latex manual.  AFAICT, it's only use
has been to show that I can check off requests.
Scott
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
