[petsc-dev] make -f gmakefile test needs a proper help message of some sort
    Matthew Knepley
    knepley at gmail.com
    Tue Jun 20 17:46:53 CDT 2017
On Tue, Jun 20, 2017 at 5:23 PM, Scott Kruger <kruger at txcorp.com> wrote:
> On 6/17/17 9:57 PM, Jed Brown wrote:
>> Matthew Knepley <knepley at gmail.com> writes:
>> On Sat, Jun 17, 2017 at 6:19 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>>    Thanks, sadly it is not helpful.
>>>> I wasn't saying it worked now, but that it was the target that should be
>>>> used to print help.
>>> <insert broken fingers message>
>> Barry's original message was addressed to Scott.  I was merely pointing
>> out a convention that is more discoverable than Barry's suggestion.  I
>> claim this was a constructive comment, not bikeshedding.  Yes, I could
>> make this change, but so could you, Barry, or anyone else.  I don't
>> think it's productive to lob the "broken fingers" criticism around.
>> It's educational and likely more accurate for the person who wrote a
>> component to maintain the docs for that component and the person making
>> the suggestion might have the 30 seconds at that moment to make a
>> constructive suggestion, but not the 10 minutes to implement it.
>> where are the current docs for it that we move to this place?
>> gmakefile has this comment.
>> # Tests can be generated by searching
>> # Percent is a wildcard (only one allowed):
>> #    make -f gmakefile test search=sys%ex2
>> # To match internal substrings (matches *ex2*):
>> #    make -f gmakefile test searchin=ex2
>> # Search and searchin can be combined:
>> #    make -f gmakefile test search='sys%' searchin=ex2
>> # For args:
>> #    make -f gmakefile test argsearch=cuda
>> # For general glob-style searching using python:
>> # NOTE: uses shell which is possibly slower and is possibly more brittle
>> #    make -f gmakefile test pysearch='sys*ex2*'
> I'll also note that per request, there is documentation
> in the developers latex manual.  AFAICT, it's only use
> has been to show that I can check off requests.
I read it :) But of course, then I forgot where it was.
   Matt
> Scott
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
> Boulder, CO 80303                Fax:   (303) 448-7756
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170620/2a32e782/attachment.html>
