[petsc-dev] make -f gmakefile test needs a proper help message of some sort
Sun Jun 18 07:06:18 CDT 2017
On Sat, Jun 17, 2017 at 9:57 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Sat, Jun 17, 2017 at 6:19 PM, Jed Brown <jed at jedbrown.org> wrote:
> >> Barry Smith <bsmith at mcs.anl.gov> writes:
> >> >   Thanks, sadly it is not helpful.
> >> I wasn't saying it worked now, but that it was the target that should be
> >> used to print help.
> > <insert broken fingers message>
> Barry's original message was addressed to Scott.  I was merely pointing
> out a convention that is more discoverable than Barry's suggestion.  I
> claim this was a constructive comment, not bikeshedding.  Yes, I could
> make this change, but so could you, Barry, or anyone else.  I don't
> think it's productive to lob the "broken fingers" criticism around.
> It's educational and likely more accurate for the person who wrote a
> component to maintain the docs for that component and the person making
> the suggestion might have the 30 seconds at that moment to make a
> constructive suggestion, but not the 10 minutes to implement it.
I know. This was irony. I always indicate irony with pseudo-HTML.
> > where are the current docs for it that we move to this place?
> gmakefile has this comment.
> # Tests can be generated by searching
> # Percent is a wildcard (only one allowed):
> #    make -f gmakefile test search=sys%ex2
> # To match internal substrings (matches *ex2*):
> #    make -f gmakefile test searchin=ex2
> # Search and searchin can be combined:
> #    make -f gmakefile test search='sys%' searchin=ex2
> # For args:
> #    make -f gmakefile test argsearch=cuda
> # For general glob-style searching using python:
> # NOTE: uses shell which is possibly slower and is possibly more brittle
> #    make -f gmakefile test pysearch='sys*ex2*'
Cool.
  Matt
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170618/58e441ff/attachment.html>
