[petsc-dev] PETSc statistics
Sean Farley sean at farley.io
Thu Jun 8 14:05:39 CDT 2017
Matthew Knepley <knepley at gmail.com> writes:
> On Tue, Jun 6, 2017 at 2:15 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
>> Hello,
>> Is there a place where I can find up-to-date statistics about the PETSc
>> user base?
>> I was thinking about these metrics:
>> * average monthly downloads
> This has email statistics: https://arxiv.org/abs/1510.01122
> Its very hard to get download statistics, since we cannot get them from
> Bitbucket, and we are at a lot of computing centers. However,
> last time we tried I think it was 400 downloads/month.
Hmmm, if only you knew of a former PETSc dev that works at Bitbucket. If
only. ;-)
So, I took this as a nice challenge to learn about our new logging tool.
It turns out that cost me actual money (running queries in AWS) so
consider this my belated birthday gift to Barry :-)
Unfortunately, we have no old data (at least that I could find) and
currently have a sliding window based on amount of data (not time). As
far as I can tell, we have about ~2.5 weeks of logs right now.
I can set up a weekly report it seems, so if you're interested in
getting a weekly report of stats, I can set that up.
Anyways, to answer Dave's original question (over a period of 7 days):
      https clones: 426
        ssh clones: 9
"archiver" means someone downloaded it via the web interface (e.g.
download a zip file of a specific tag)
But what about country / region? Well, I've attached a PDF of a fancy
map (final row is a sum):
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170608/aac8d8ed/attachment.sig>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170608/aac8d8ed/attachment.pdf>
Hope that helps!
