[petsc-dev] Syntax for test
Sun Jun 4 21:28:44 CDT 2017
On Sun, Jun 4, 2017 at 8:39 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Looks like you might have t use 'requires: !__float128'
> https://bitbucket.org/petsc/petsc/src/a2a52772660a7b1f40caa55c19eee1
> 41804c7712/config/gmakegentest.py?at=master&fileviewer=file-view-default#
> gmakegentest.py-35
Thanks Satish, right again.
  Matt
Satish
> On Sun, 4 Jun 2017, Matthew Knepley wrote:
> > Is this the right way to block out quad?
> > https://bitbucket.org/petsc/petsc/commits/af5d1f11a8350d39ebdf2636cd13e8
> 1c68c0afba
> > The tests still look like they are running.
> >    Matt
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170604/35307192/attachment.html>
