[petsc-dev] Syntax for test
Sun Jun 4 20:39:45 CDT 2017
Looks like you might have t use 'requires: !__float128'
https://bitbucket.org/petsc/petsc/src/a2a52772660a7b1f40caa55c19eee141804c7712/config/gmakegentest.py?at=master&fileviewer=file-view-default#gmakegentest.py-35
Satish
On Sun, 4 Jun 2017, Matthew Knepley wrote:
> Is this the right way to block out quad?
> https://bitbucket.org/petsc/petsc/commits/af5d1f11a8350d39ebdf2636cd13e81c68c0afba
> The tests still look like they are running.
>    Matt
