[petsc-dev] Some warnings in Master branch
    Zhang, Hong
    hongzhang at anl.gov
    Mon Jun  5 11:29:23 CDT 2017
The first one looks like a bug.
CC-128 craycc: WARNING File = /global/u2/h/hongzh/Project/petsc/src/dm/impls/plex/plextree.c, Line = 3149
  The indicated loop is not reachable from preceding code.
          SETERRQ(PETSC_COMM_SELF,PETSC_ERR_SUP,"Unsupported discretization object");CHKERRQ(ierr);
ftn-1279 crayftn: WARNING TSADAPTEQUALS, File = ../../../global/u2/h/hongzh/Project/petsc/src/ts/f90-mod/petsctsmod.F, Line = 66, Column = 32
  Procedure "TSADAPTEQUALS" is defined at line 32 (/global/u2/h/hongzh/Project/petsc/src/ts/f90-mod/petsctsmod.F).  The type of this argument does not agree with dummy argument "A".
ftn-1279 crayftn: WARNING TSADAPTEQUALS, File = ../../../global/u2/h/hongzh/Project/petsc/src/ts/f90-mod/petsctsmod.F, Line = 66, Column = 34
  Procedure "TSADAPTEQUALS" is defined at line 32 (/global/u2/h/hongzh/Project/petsc/src/ts/f90-mod/petsctsmod.F).  The type of this argument does not agree with dummy argument "B".
Hong (Mr.)
