[petsc-dev] How to generate doc locally ?
Satish Balay
balay at mcs.anl.gov
Sun Jul 16 11:37:32 CDT 2017
On Sun, 16 Jul 2017, Karl Rupp wrote:
> Hi Franck,
> > Following, the online doc, I have configured PETSc with: ./configure
> > --download-sowing --download-c2html
> > Now, I run:
> > > > make alldoc LOC=/path/to/petsc
And also PETSC_DIR should be set - and make should be invoked in PETSC_DIR. To be more precise.
cd /home/fghoussen/Documents/INRIA/petsc/
make PETSC_DIR=$PWD LOC=$PWD alldoc
Our docs are built daily - and the logs [for maint/master/next] built
by bin/maint/builddist and available at:
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/
I see a couple of errors with master/next - so pushed fixes.
Satish
> that looks fine. There are also subtargets 'alldoc1', 'alldoc2', etc.
> available if you need finer granularity.
> > I get lots of errors like this along the way (I don't even know that's a cit
> > file !):
> > html in: /home/fghoussen/Documents/INRIA/petsc/tutorials
> > sed: can't read
> > /home/fghoussen/Documents/INRIA/petsc//docs/manualpages/manualpages.cit: No
> > such file or directory
> > /home/fghoussen/Documents/INRIA/petsc/lib/petsc/conf/rules:699: recipe for
> > target 'html' failed
> > make[2]: [html] Error 2 (ignored)
> > And finally breaks like this:
> > Updating generated html files with petsc version, date, canonical URL info
> > find: unknown predicate `-o -type f -wholename
> > share/petsc/saws/linearsolveroptions.html -prune -o -type f -wholename
> > tutorials/HandsOnExercise.html -prune -o -type f -wholena
> > me tutorials/TAOHandsOnExercise.html -prune'
> > Try 'find --help' for more information.
> Can you please send us the complete output? The .cit file is an intermediate
> result file, so the source of the error is at an earlier stage.
> Best regards,
> Karli
