[petsc-dev] configure failure
Mark Adams mfadams at lbl.gov
Thu Jul 13 12:32:48 CDT 2017
On Thu, Jul 13, 2017 at 12:21 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Toby, this is from the p4est configure:
> o---------------------------------------
> | Checking MPI and related programs
> checking whether we are using MPI... yes
> checking whether we are using MPI I/O... yes
> checking whether we are using MPI_Init_thread... yes
> checking for mpiexec... no
> checking for mpirun... no
> configure:                             F77 set to ftn
> configure:                              FC set to ftn
> configure:                              CC set to cc
> configure:                             CXX set to CC
> checking whether the Fortran 77 compiler works... yes
> checking for Fortran 77 compiler default output file name... a.out
> checking for suffix of executables...
> checking whether we are cross compiling...configure: error: in
> `/global/u2/m/madams/petsc/arch-cori-knl-opt-intel/
> externalpackages/git.p4est':
> configure: error: cannot run Fortran 77 compiled programs.
> If you meant to cross compile, use `--host'.
> See `config.log' for more details
> Mark, gets us /global/u2/m/madams/petsc/arch-cori-knl-opt-intel/
> externalpackages/git.p4est/config.log
>   Thanks,
>      Matt
> On Thu, Jul 13, 2017 at 11:15 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> I always get this error on Cori at NERSC, KNL, but I can usually rerun
>> configure and it runs the second time. Well, I can't seem to get this to
>> work now.
>> Thanks,
>> Mark
> experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170713/64a8d3e5/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170713/64a8d3e5/attachment.obj>
