[petsc-dev] Matrix-free preconditioners
    Jed Brown
    jed at jedbrown.org
    Sat Jan 28 07:58:12 CST 2017
That's pretty much it.  You can probably easily apply the local part of
the operator so you can do a block Jacobi by running an iterative method
on subdomains.  Depending on the preconditioner, you might be able to
apply Neumann subdomain operators -- a research topic would be to set up
a BDDC-type method without explicit subdomain matrices.
Chris Eldred <chris.eldred at gmail.com> writes:
> Hey Petsc Dev,
> I had some questions about preconditioners, and I was hoping the list
> could help me out. Specifically, if I have a MatShell with the ability
> to compute the diagonal of the matrix; and a geometric multigrid
> hierarchy with appropriate operators defined; what are my
> preconditioner options?
> From reading the manual and the doc pages, it appears that my options are
> 1) Jacobi (and block variants)
> 2) Multigrid
> plus the ability to use Fieldsplit for block matrices. Then within
> multigrid, any iterative KSP (ie one that requires only matrix-vector
> products) can be used as a smoother, with the basic ones being
> Chebyshev and Richardson using Jacobi as a preconditioner.
> Is this correct? Is there anything else?
> Regards,
> Chris Eldred
> Chris Eldred
> https://www.math.univ-paris13.fr/~eldred/
> Postdoctoral Fellow, LAGA, University of Paris 13
> PhD, Atmospheric Science, Colorado State University, 2015
> DOE Computational Science Graduate Fellow (Alumni)
> B.S. Applied Computational Physics, Carnegie Mellon University, 2009
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170128/e25284a3/attachment.sig>
