[petsc-dev] Matrix-free preconditioners
Chris Eldred chris.eldred at gmail.com
Mon Jan 30 03:49:56 CST 2017
Hey Jed,
That's what I thought, thanks for the clarification!
Chris Eldred
On Sat, Jan 28, 2017 at 2:58 PM, Jed Brown <jed at jedbrown.org> wrote:
> That's pretty much it.  You can probably easily apply the local part of
> the operator so you can do a block Jacobi by running an iterative method
> on subdomains.  Depending on the preconditioner, you might be able to
> apply Neumann subdomain operators -- a research topic would be to set up
> a BDDC-type method without explicit subdomain matrices.
> Chris Eldred <chris.eldred at gmail.com> writes:
>> Hey Petsc Dev,
>> I had some questions about preconditioners, and I was hoping the list
>> could help me out. Specifically, if I have a MatShell with the ability
>> to compute the diagonal of the matrix; and a geometric multigrid
>> hierarchy with appropriate operators defined; what are my
>> preconditioner options?
>> From reading the manual and the doc pages, it appears that my options are
>> 1) Jacobi (and block variants)
>> 2) Multigrid
>> plus the ability to use Fieldsplit for block matrices. Then within
>> multigrid, any iterative KSP (ie one that requires only matrix-vector
>> products) can be used as a smoother, with the basic ones being
>> Chebyshev and Richardson using Jacobi as a preconditioner.
>> Is this correct? Is there anything else?
>> Regards,
>> Chris Eldred
>> Chris Eldred
>> https://www.math.univ-paris13.fr/~eldred/
>> Postdoctoral Fellow, LAGA, University of Paris 13
>> PhD, Atmospheric Science, Colorado State University, 2015
>> DOE Computational Science Graduate Fellow (Alumni)
>> B.S. Applied Computational Physics, Carnegie Mellon University, 2009
Chris Eldred
