[petsc-dev] new test suite stops on example compile error
    Satish Balay
    balay at mcs.anl.gov
    Fri Jan 27 14:37:27 CST 2017
Scott,
The issue I was refering to was :
arch-linux-pkgs-valgrind/tests/src/dm/impls/plex/examples/tests/ex15.o: In function `main':
/sandbox/petsc/petsc.clone-4/src/dm/impls/plex/examples/tests/ex15.c:84: undefined reference to `PetscViewerHDF5Open'
/sandbox/petsc/petsc.clone-4/src/dm/impls/plex/examples/tests/ex15.c:108: undefined reference to `PetscViewerHDF5Open'
collect2: error: ld returned 1 exit status
gmake[2]: *** [arch-linux-pkgs-valgrind/tests/src/dm/impls/plex/examples/tests/ex15] Error 1
gmake[2]: *** Waiting for unfinished jobs....
gmake[1]: [allgtest] Error 1 (ignored)
Satish
On Fri, 27 Jan 2017, Scott Kruger wrote:
> This appears to be the legacy builds, not the new system:
> Possible problem with ex115_5, diffs above
> ******* Testing: testexamples_SUPERLU_DIST *******
> /usr/bin/sh: line 1:  1090 Killed                  ( cd $dir; if [ nofoo =
> dotfoo ]; then
>     printf ".";
> fi; if [ nofoo = foo -o nofoo = yesfoo -o nofoo = dirfoo ]; then
>     echo testexamples_SUPERLU_DIST in: `pwd`;
> fi; /usr/bin/gmake --no-print-directory tree ACTION=testexamples_SUPERLU_DIST
> PETSC_ARCH=arch-linux-pkgs-valgrind LOC= DATAFILESPATH=/home/petsc/datafiles
> BASE_DIR= PRINT_PROGRESS=no )
> Finished Build on el7.novalocal arch-linux-pkgs-valgrind Fri Jan 27 08:35:12
> CST 2017
> X******************************************************X
> On 1/27/17 12:59 PM, Satish Balay wrote:
> > Jed,
> > I see the test build stops on encountering errors. This is fine for
> > library build - but for tests - I think its best if it skips this test
> > and continues with the remaining tests. Is this possible?
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/01/27/examples_next_arch-linux-pkgs-valgrind_el6.log
> > Satish
