[petsc-dev] new test suite stops on example compile error
Scott Kruger
kruger at txcorp.com
Fri Jan 27 14:20:46 CST 2017
This appears to be the legacy builds, not the new system:
Possible problem with ex115_5, diffs above
******* Testing: testexamples_SUPERLU_DIST *******
/usr/bin/sh: line 1: 1090 Killed ( cd $dir; if [ nofoo
= dotfoo ]; then
printf ".";
fi; if [ nofoo = foo -o nofoo = yesfoo -o nofoo = dirfoo ]; then
echo testexamples_SUPERLU_DIST in: `pwd`;
fi; /usr/bin/gmake --no-print-directory tree
ACTION=testexamples_SUPERLU_DIST PETSC_ARCH=arch-linux-pkgs-valgrind
LOC= DATAFILESPATH=/home/petsc/datafiles BASE_DIR= PRINT_PROGRESS=no )
Finished Build on el7.novalocal arch-linux-pkgs-valgrind Fri Jan 27
08:35:12 CST 2017
X******************************************************X
On 1/27/17 12:59 PM, Satish Balay wrote:
> Jed,
> I see the test build stops on encountering errors. This is fine for
> library build - but for tests - I think its best if it skips this test
> and continues with the remaining tests. Is this possible?
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/01/27/examples_next_arch-linux-pkgs-valgrind_el6.log
> Satish
Tech-X Corporation kruger at txcorp.com
5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
Boulder, CO 80303 Fax: (303) 448-7756
