[petsc-dev] new test suite stops on example compile error
Jed Brown
jed at jedbrown.org
Fri Jan 27 14:21:00 CST 2017
make -k
Satish Balay <balay at mcs.anl.gov> writes:
> Jed,
> I see the test build stops on encountering errors. This is fine for
> library build - but for tests - I think its best if it skips this test
> and continues with the remaining tests. Is this possible?
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/01/27/examples_next_arch-linux-pkgs-valgrind_el6.log
> Satish
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170127/d1d39333/attachment.sig>
