[petsc-dev] new test suite stops on example compile error
    Satish Balay
    balay at mcs.anl.gov
    Fri Jan 27 14:34:47 CST 2017
Thanks! pushed this change.
Satish
On Fri, 27 Jan 2017, Jed Brown wrote:
> make -k
> Satish Balay <balay at mcs.anl.gov> writes:
> > Jed,
> > I see the test build stops on encountering errors. This is fine for
> > library build - but for tests - I think its best if it skips this test
> > and continues with the remaining tests. Is this possible?
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/01/27/examples_next_arch-linux-pkgs-valgrind_el6.log
> > Satish
