[petsc-dev] new test suite stops on example compile error
Fri Jan 27 13:59:28 CST 2017
Jed,
I see the test build stops on encountering errors. This is fine for
library build - but for tests - I think its best if it skips this test
and continues with the remaining tests. Is this possible?
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/01/27/examples_next_arch-linux-pkgs-valgrind_el6.log
Satish
