[petsc-dev] REPLACE for tests
    Scott Kruger
    kruger at txcorp.com
    Thu Jan 26 12:08:08 CST 2017
Fixed.
https://bitbucket.org/petsc/petsc/pull-requests/625
On 1/25/17 4:22 PM, Matthew Knepley wrote:
> Does not seem to work in master:
>  1knepley/feature-plex-tests-new +$|MERGING:/PETSc3/petsc/petsc-dev$
> PETSC_ARCH=arch-c-exodus-master make -f gmakefile test
> search=ts_tutorials-runex48% REPLACE=1
>         TEST ts_tutorials-runex48_0
> ok ts_tutorials-ex48_0
> not ok diff-ts_tutorials-ex48_0
> #Error! file1 check failed:
> /PETSc3/petsc/petsc-dev/src/ts/examples/tutorials/output/ex48_0.out
> #   Summary
> # FAILED diff-ts_tutorials-ex48_0
> # success 1/2 tests (50.0%)
> # failed 1/2 tests (50.0%)
> # todo 0/2 tests (0.0%)
> # skip 0/2 tests (0.0%)
> knepley/feature-plex-tests-new +$|MERGING:/PETSc3/petsc/petsc-dev$ ls
> ls src/ts/examples/tutorials/output/ex48_0.out
> ls: src/ts/examples/tutorials/output/ex48_0.out: No such file or directory
>   Thanks,
>      Matt
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
